brookie
#1 Posted : Wednesday, April 17, 2013 2:59:41 AM(UTC)
brookie
I have a5000 that will not agitate. It will fill and drain . The agitator is not stuck and the belts are in good shape. I get no humming or any other sound out of it when it is supposed to agitate. This makes me think the motor is not getting a command to to run...I have made several assumptions that may be incorrect.
I assume the lid switch is good because it spins...
I assume the motor is good because it spins...
The transmission turns freely clockwise and the belts show no sign of wear or smoking so I assume the transmission is good.
Please help.
P.S. If all you have to say is I had the same problem and I bought a new washer...no need for you to respond.
fairbank56
#2 Posted : Wednesday, April 17, 2013 4:30:06 AM(UTC)
fairbank56
Groups: Expert
Yes, lid switch is ok and motor is likely ok. You may have a problem in the water level system. There is an air dome on the side of the outer tub that has a tube that goes from it to a pressure switch behind the control panel. As the water level rises in the tub, air pressure will activate the switch which turns off the water inlet valves and turns on agitation. Since your water is shutting off, the switch is activating but the contacts may be faulty. You can jump out the switch but I do not have a wiring diagram for that washer, I can help further if you provide a clear photo of the diagram. Standard color code for later models are white (or gray), yellow and brown. Jump the white (or gray) to yellow to bypass contacts for agitation.
Eric
brookie
#3 Posted : Wednesday, April 17, 2013 6:55:58 AM(UTC)
brookie
OK thanks. I will check it next week and get back to you. If I can't figure the switch out I will post a clear photo of the control panel.
brookie
#4 Posted : Tuesday, April 23, 2013 4:30:53 AM(UTC)
brookie
Thanks Fairbanks !
The yellow wire to the agitation switch was broken off at the connector. Replaced connector and washer works good. I didn't even have to buy anything !
Samsung Washer No Agitation or Spin (Washer Repair)
by amappliancewi 2/7/2024 10:24:03 AM(UTC)
GE Washer model GFAN1000L2WW. Stucked during the washing process with no agitation. (Washer Repair)
by Guest 8/24/2023 4:22:18 PM(UTC)
Maytag LA506 - No Agitation Wash Cycle (Washer Repair)
by tjg79 9/17/2021 12:59:40 PM(UTC)
No agitation, drain or spin (Washer Repair)
by Cathyware 5/23/2017 12:57:12 PM(UTC)
No agitation/spin; does fill & drain (Washer Repair)
by ICANFIXTHAT2 5/4/2017 1:08:57 PM(UTC)
Frigidaire Washer - No agitation and no spin (Washer Repair)
by jmplsjones 6/29/2015 7:30:44 AM(UTC)
No Agitation (Washer Repair)
by Richard Aragon 4/28/2015 11:41:44 AM(UTC)
Washer Fills but No Agitation, Spin, Rinse, or Drain (Washer Repair)
by IxIGhosTIxI 1/21/2015 6:20:44 AM(UTC)
New Motor, Spin, No Agitation (Washer Repair)
by Rawger11 8/24/2014 1:30:52 PM(UTC)
Motor hums then stops, no agitations, rinse or spin (Washer Repair)
by denebach 8/6/2014 7:31:43 AM(UTC)
Whirlpool washer-no agitation or spin; grinding noise (Washer Repair)
by Blaiser 7/8/2014 9:39:04 PM(UTC)
No agitation nor spin (Washer Repair)
by Johnny Brewer 6/11/2014 4:47:13 PM(UTC)
Spins, No agitation (Washer Repair)
by Libraman2k1 4/14/2014 8:11:40 PM(UTC)
Whirlpool Ultimate Care ll no agitation drain or spin (Dishwasher Repair)
by Kbywg 1/20/2014 9:52:37 AM(UTC)
Washer spins, drains, no agitation (Washer Repair)
by aws1963 1/2/2014 2:44:55 PM(UTC)
