Johnny Brewer
#1 Posted : Wednesday, June 11, 2014 4:47:13 PM(UTC)
Johnny Brewer
Washer won't agitate nor spin.
Lid switch tests Ok... for both circuits.
Replaced control board assembly... No help.
Belt is good and on proper.
Motor never starts. Nor does the LED ever light on the board atop the motor.
What else could it be?
sidfink43
#2 Posted : Saturday, June 14, 2014 12:29:08 PM(UTC)
sidfink43
In general this would indicate a bad motor/inverter (the two are mated together) but try a reset first. If that does not work the new motor is probably the most likely solution.
If you buy from this site and that does not fix the problem you can return it.
