nrclean
#1 Posted : Wednesday, March 7, 2012 9:52:46 AM(UTC)
nrclean
Hi - read your previous questions for ice maker not making ice & leaking water - on site which fowarded to yours for part , the had review advised this,
1. " Its either the water inlet valve or the ice maker. The way to tell is turn the water back on and unplug the refrigerator, if the water doesn't stop, then its the valve. If the water does stop when you unplug the refrigerator, then its the ice maker."
I am confused - ice maker arm down - water leaks out - arm up stops - did #1 .. put arm down .. water leaks out .. pull plug on machine it stops // switched plugs on water valve - hit water paddle water leaks out of icemaker down & out frt of door .. let off paddle stops ... with ice maker on ..... i believe icemaker -- would like your advise --
Thank yoy, John
Jerry / APP Team
#2 Posted : Wednesday, March 7, 2012 11:21:52 AM(UTC)
mattt
Groups:
Hello. The problem you described sounds like the ice maker has failed.
Lg ice maker leaking (Refrigerator & Freezer Repair)
by Guest 4/10/2024 2:58:55 PM(UTC)
KitchenAid KFIS27CXMS3 ice maker Leaking (Refrigerator & Freezer Repair)
by Scott1969 2/15/2021 10:39:41 AM(UTC)
Whirlpool WRF535SMBM00 Bottom Freezer Ice Maker Leaking - Water Adjustment (Refrigerator & Freezer Repair)
by brytyhokie 12/10/2019 3:10:24 PM(UTC)
Whirlpool Ice Maker Leaking (Refrigerator & Freezer Repair)
by WayneLee 3/7/2019 6:18:13 AM(UTC)
Ice Maker Leaking a lot (Refrigerator & Freezer Repair)
by agdodge4x4 4/19/2016 8:07:56 AM(UTC)
LG Refrigerator Ice Maker Leaking (Refrigerator & Freezer Repair)
by jimdeprado 4/17/2014 5:06:08 AM(UTC)
ice maker leaking.... not the usual problems (Refrigerator & Freezer Repair)
by killermrob83 10/8/2013 4:30:56 PM(UTC)
GE Profile PSS26NG Arctica - Ice Maker leaking (Refrigerator & Freezer Repair)
by jimatx 12/11/2012 6:24:01 AM(UTC)
Water Supply to Ice Maker Leaking (Refrigerator & Freezer Repair)
by Salt1972 9/30/2012 5:46:09 AM(UTC)
Ice maker leaking inside freezer (Refrigerator & Freezer Repair)
by Dirtgirl13 3/15/2012 9:33:27 PM(UTC)
Ice Maker Leaking - Sub Zero 561 (Refrigerator & Freezer Repair)
by TimTool 3/9/2012 8:35:39 AM(UTC)
front display error "Er IF", ice maker leaking (Refrigerator & Freezer Repair)
by b_brown7 3/1/2012 10:17:02 AM(UTC)
Ice Maker Leaking? (Refrigerator & Freezer Repair)
by tchapman 9/12/2011 1:16:58 PM(UTC)
GE Profile Refrigerator Ice Maker Leaking (Refrigerator & Freezer Repair)
by StamMKelly53 5/24/2011 5:23:39 AM(UTC)
Ice maker leaking (Refrigerator & Freezer Repair)
by taberah 5/4/2011 3:45:46 PM(UTC)
