6 year old GE Profile Arctica - Ice maker is leaking water into the bucket...
It stopped making ice a few days ago so I did a reset (turned off, waited 15 seconds, turned on, pushed the paddle 3 times) and it cycled the cubes out of the maker into the bucket, and then when it pumped water into the maker I noticed the water leaking into the bucket.
Is this a common problem with this model?
Should I just replace the ice maker or is there another issue not yet diagnosed?
thanks - Jim
I snapped a couple of pics showing the water droplets after the water was pumped in. This first shot was as the water started to leak, you can see the primary location where the water was leaking / pooling. The second picture shows two spots where I noticed water dripping after the pump disengaged and the water had (mostly) run out of the maker and was just dripping into the bucket at this point.
Groups: APP Team
