The liner on the tray as separated, top and bottom, and pieces of the liner have frozen to the cubes and come free. This has allowed water to wick itself up the liner and subsequently leak out at the bottom of the tray. Is there some kind of a food safe liner that I can apply to the tray to make this unit functional again? Thank you for your time and consideration. Rob
I cannot find any info on the given model number. Please check it.
As far as I know there is nothing available to re-coat the tray. You have to replace it. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  I cannot find any info on the given model number. Please check it.
As far as I know there is nothing available to re-coat the tray. You have to replace it. That's the model number right off of the front of the IM, behind the cover. The model number for the refrigerator is BC120TW. I didn't think there would be a product to recoat the tray with. Thank you for responding,
Originally Posted by: killermrob83  That's the model number right off of the front of the IM, behind the cover. The model number for the refrigerator is BC120TW.
I didn't think there would be a product to recoat the tray with. Thank you for responding, OK, so have finally figured out that the model number is BCI(not 1)20TW. Sorry about the confusion, but the figure is just a straight up and down line that does not lend a hand in determining if it is a letter or number. Can anyone help me in determining the correct part number so I can get this part ordered? I called Amana and they direct me to some third part parts distributor that will not give out part numbers, but will sell a part at a very high (IMO) price ($157 + $20 S/H). For part numbers, I have seen W10190965, D7824706, D7824706Q, 106 626640, and the list goes on. If these are all correct part numbers, just different manufacturers, which is the better quality part? Thanks again for all of the assistance.
Did you get your part. If not here is what comes up at AppliancePartsPros. Click on the picture for more info on the part. looks like just the tray is not available. Part number: AP4135008
