nrclean
#1 Posted : 13 years ago
nrclean
Hi - read your previous questions for ice maker not making ice & leaking water - on site which fowarded to yours for part , the had review advised this,
1. " Its either the water inlet valve or the ice maker. The way to tell is turn the water back on and unplug the refrigerator, if the water doesn't stop, then its the valve. If the water does stop when you unplug the refrigerator, then its the ice maker."
I am confused - ice maker arm down - water leaks out - arm up stops - did #1 .. put arm down .. water leaks out .. pull plug on machine it stops // switched plugs on water valve - hit water paddle water leaks out of icemaker down & out frt of door .. let off paddle stops ... with ice maker on ..... i believe icemaker -- would like your advise --
Thank yoy, John
Jerry / APP Team
#2 Posted : 13 years ago
mattt
Groups:
Hello. The problem you described sounds like the ice maker has failed.
Lg ice maker leaking (Refrigerator & Freezer Repair)
by Guest 12 months ago
KitchenAid KFIS27CXMS3 ice maker Leaking (Refrigerator & Freezer Repair)
by Scott1969 4 years ago
Whirlpool WRF535SMBM00 Bottom Freezer Ice Maker Leaking - Water Adjustment (Refrigerator & Freezer Repair)
by brytyhokie 5 years ago
Whirlpool Ice Maker Leaking (Refrigerator & Freezer Repair)
by WayneLee 6 years ago
Ice Maker Leaking a lot (Refrigerator & Freezer Repair)
by agdodge4x4 9 years ago
LG Refrigerator Ice Maker Leaking (Refrigerator & Freezer Repair)
by jimdeprado 11 years ago
ice maker leaking.... not the usual problems (Refrigerator & Freezer Repair)
by killermrob83 11 years ago
GE Profile PSS26NG Arctica - Ice Maker leaking (Refrigerator & Freezer Repair)
by jimatx 12 years ago
Water Supply to Ice Maker Leaking (Refrigerator & Freezer Repair)
by Salt1972 13 years ago
Ice maker leaking inside freezer (Refrigerator & Freezer Repair)
by Dirtgirl13 13 years ago
Ice Maker Leaking - Sub Zero 561 (Refrigerator & Freezer Repair)
by TimTool 13 years ago
front display error "Er IF", ice maker leaking (Refrigerator & Freezer Repair)
by b_brown7 13 years ago
Ice Maker Leaking? (Refrigerator & Freezer Repair)
by tchapman 14 years ago
GE Profile Refrigerator Ice Maker Leaking (Refrigerator & Freezer Repair)
by StamMKelly53 14 years ago
Ice maker leaking (Refrigerator & Freezer Repair)
by taberah 14 years ago
