Hi - read your previous questions for ice maker not making ice & leaking water - on site which fowarded to yours for part , the had review advised this, 1. " Its either the water inlet valve or the ice maker. The way to tell is turn the water back on and unplug the refrigerator, if the water doesn't stop, then its the valve. If the water does stop when you unplug the refrigerator, then its the ice maker."
I am confused - ice maker arm down - water leaks out - arm up stops - did #1 .. put arm down .. water leaks out .. pull plug on machine it stops // switched plugs on water valve - hit water paddle water leaks out of icemaker down & out frt of door .. let off paddle stops ... with ice maker on ..... i believe icemaker -- would like your advise -- Thank yoy, John
Hello. The problem you described sounds like the ice maker has failed.
