layoutman
#1 Posted : Friday, April 17, 2009 11:39:42 AM(UTC)
layoutman
My Maytag Atlantis was making a screech after it went through the spin cycles. Now it doesn't agitate at all. I can hear the motor go through it's normal process. Could some one tell what's wrong ?
THANKS
#2 Posted : Friday, April 17, 2009 2:18:46 PM(UTC)
Does it drain and/or spin? Does the motor run?
layoutman
#3 Posted : Saturday, April 18, 2009 8:24:57 AM(UTC)
layoutman
Yes Ican hear the motor go through it's washing cycles,but the tub doesn't agitate or spin. It also delivers water and drains properly.
#4 Posted : Saturday, April 18, 2009 3:35:10 PM(UTC)
Remove the front panel and check the belt. Check the thrust bearing (#3 on the diagram) as described in the Service Manual.
Here are the breakdown diagrams and Replacement parts for MAYTAG MAV7600AWQ | AppliancePartsPros.com
Samsung Washer No Agitation or Spin (Washer Repair)
by amappliancewi 2/7/2024 10:24:03 AM(UTC)
GE Washer model GFAN1000L2WW. Stucked during the washing process with no agitation. (Washer Repair)
by Guest 8/24/2023 4:22:18 PM(UTC)
Maytag LA506 - No Agitation Wash Cycle (Washer Repair)
by tjg79 9/17/2021 12:59:40 PM(UTC)
No agitation, drain or spin (Washer Repair)
by Cathyware 5/23/2017 12:57:12 PM(UTC)
No agitation/spin; does fill & drain (Washer Repair)
by ICANFIXTHAT2 5/4/2017 1:08:57 PM(UTC)
Frigidaire Washer - No agitation and no spin (Washer Repair)
by jmplsjones 6/29/2015 7:30:44 AM(UTC)
No Agitation (Washer Repair)
by Richard Aragon 4/28/2015 11:41:44 AM(UTC)
Washer Fills but No Agitation, Spin, Rinse, or Drain (Washer Repair)
by IxIGhosTIxI 1/21/2015 6:20:44 AM(UTC)
New Motor, Spin, No Agitation (Washer Repair)
by Rawger11 8/24/2014 1:30:52 PM(UTC)
Motor hums then stops, no agitations, rinse or spin (Washer Repair)
by denebach 8/6/2014 7:31:43 AM(UTC)
Whirlpool washer-no agitation or spin; grinding noise (Washer Repair)
by Blaiser 7/8/2014 9:39:04 PM(UTC)
No agitation nor spin (Washer Repair)
by Johnny Brewer 6/11/2014 4:47:13 PM(UTC)
Spins, No agitation (Washer Repair)
by Libraman2k1 4/14/2014 8:11:40 PM(UTC)
Whirlpool Ultimate Care ll no agitation drain or spin (Dishwasher Repair)
by Kbywg 1/20/2014 9:52:37 AM(UTC)
Washer spins, drains, no agitation (Washer Repair)
by aws1963 1/2/2014 2:44:55 PM(UTC)
