jwo
#1 Posted : Saturday, May 11, 2013 6:09:29 AM(UTC)
jwo
only getting hot water for a short time on hot cold.no water on warm cold or cold cold
fairbank56
#2 Posted : Saturday, May 11, 2013 6:50:57 AM(UTC)
fairbank56
Groups: Expert
Swap connectors on the water inlet valve solenoids and select hot/cold. If no cold water, inlet valve is bad or screen clogged or no cold water supply. If you do get cold water, ATC is likely bad.
Eric
Maytag MAV7700AWW no cold water (Washer Repair)
by Guest 12/16/2022 6:01:36 PM(UTC)
No cold water on fill but works on rinse (Washer Repair)
by kedester 10/8/2017 6:15:44 PM(UTC)
Roper Top load Washer No Cold Water (Washer Repair)
by James0188 5/4/2017 1:30:06 PM(UTC)
Maytag washer has no cold water (Washer Repair)
by Calabashman 1/28/2017 2:29:58 PM(UTC)
Kenmore - no cold water (Washer Repair)
by mostrander6@yahoo.com 8/28/2015 5:53:33 AM(UTC)
No Cold Water (Dishwasher Repair)
by dschertz7@gmail.com 8/5/2015 8:33:29 AM(UTC)
by grabhorn 8/4/2015 4:41:04 PM(UTC)
No cold water during washer fill cycle (Washer Repair)
by YankeeDoodle 5/26/2015 7:27:06 PM(UTC)
No cold water after relacing drain pump...fred2222 (Washer Repair)
by fred2222 3/31/2014 4:51:43 PM(UTC)
Maytag Atlantis - No Cold Water, only warm and hot (Washer Repair)
by fitzglitz 2/1/2014 10:54:39 AM(UTC)
no cold water but getting hot water (Washer Repair)
by BrokenWhirlpoolWasher 9/19/2013 1:21:48 PM(UTC)
No cold water (Washer Repair)
by bluebarn 8/22/2013 6:27:38 PM(UTC)
GE Front Load Washer No Cold Water Fill (Washer Repair)
by RaB1 2/11/2013 1:02:10 PM(UTC)
GE Front Loader Waher No Cold Water (Washer Repair)
by Brokenwashe 2/4/2013 5:56:02 AM(UTC)
Wash cycle-no cold water; Rinse cycle gets cold water (Washer Repair)
by Cois Tine 11/20/2012 8:30:31 PM(UTC)
