bluebarn
#1 Posted : Thursday, August 22, 2013 6:27:38 PM(UTC)
bluebarn
On my washing machine hot water runs fine.but the cold water only trickles in.I replaced the mixing valve & the temperature control switch. The water to the machine runs full stream. What else could be the problem? Thank you, I await your reply,
HumboldtRepairMan
#2 Posted : Thursday, August 22, 2013 6:54:45 PM(UTC)
HumboldtRepairMan
Remove the hoses grab a bucket and turn your cold hose into the bucket and turn on and see if you have good amount coming in from the wall......if that doesn't do it there's filter screens where you attach the feed hoses to the unit at the inlet valve, clean them out.
bluebarn
#3 Posted : Friday, August 23, 2013 4:46:50 PM(UTC)
bluebarn
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
bluebarn
#4 Posted : Friday, August 23, 2013 4:50:45 PM(UTC)
bluebarn
We have done all of the above plus the new parts & still not a good flow of cold water in the machine. Thank you, we await your reply.
fairbank56
#5 Posted : Friday, August 23, 2013 6:53:22 PM(UTC)
fairbank56
Groups: Expert
Are you using flood safe washer hoses or valves? If so, this is likely your problem. If not, swap the electrical connectors on the water valve solenoids and select hot water wash. If you don't get good cold water flow, the valve is faulty or you don't have proper flow from your cold water supply. If you do get good cold water flow this way, you may have a bad wiring connection or timer problem although the solenoid valves usually either work or don't, they generally don't just work partially, but anything is possible.
Eric
bluebarn
#6 Posted : Tuesday, September 3, 2013 5:26:08 PM(UTC)
bluebarn
Eric
Thank you for the above information. All sounds good and the first chance we get we will try it. Will let you know the results.
Maytag MAV7700AWW no cold water (Washer Repair)
by Guest 12/16/2022 6:01:36 PM(UTC)
No cold water on fill but works on rinse (Washer Repair)
by kedester 10/8/2017 6:15:44 PM(UTC)
Roper Top load Washer No Cold Water (Washer Repair)
by James0188 5/4/2017 1:30:06 PM(UTC)
Maytag washer has no cold water (Washer Repair)
by Calabashman 1/28/2017 2:29:58 PM(UTC)
Kenmore - no cold water (Washer Repair)
by mostrander6@yahoo.com 8/28/2015 5:53:33 AM(UTC)
No Cold Water (Dishwasher Repair)
by dschertz7@gmail.com 8/5/2015 8:33:29 AM(UTC)
by grabhorn 8/4/2015 4:41:04 PM(UTC)
No cold water during washer fill cycle (Washer Repair)
by YankeeDoodle 5/26/2015 7:27:06 PM(UTC)
No cold water after relacing drain pump...fred2222 (Washer Repair)
by fred2222 3/31/2014 4:51:43 PM(UTC)
Maytag Atlantis - No Cold Water, only warm and hot (Washer Repair)
by fitzglitz 2/1/2014 10:54:39 AM(UTC)
no cold water but getting hot water (Washer Repair)
by BrokenWhirlpoolWasher 9/19/2013 1:21:48 PM(UTC)
by jwo 5/11/2013 6:09:29 AM(UTC)
GE Front Load Washer No Cold Water Fill (Washer Repair)
by RaB1 2/11/2013 1:02:10 PM(UTC)
GE Front Loader Waher No Cold Water (Washer Repair)
by Brokenwashe 2/4/2013 5:56:02 AM(UTC)
Wash cycle-no cold water; Rinse cycle gets cold water (Washer Repair)
by Cois Tine 11/20/2012 8:30:31 PM(UTC)
