jemetz49
#1 Posted : Friday, February 19, 2010 9:44:25 AM(UTC)
jemetz49
opened dryer to replace drum rollers,reassembled,had small spark on termial block,ground wire was touching common wire,now all i get is the buzzer to work when i open the door.
any insight, mabe blown fuse and where is it located.
Jim
#2 Posted : Friday, February 19, 2010 5:50:04 PM(UTC)
Hi Jim,
Have you checked the circuit breakers?
jemetz49
#3 Posted : Friday, February 19, 2010 9:12:10 PM(UTC)
jemetz49
yes I checked them because when it sparked it tripped the breaker for the dryer. i have power to the termial block 110 on each leg,
the only power i have is the buzzer when i open the door and push the start button.
thanks ,
jim
#4 Posted : Saturday, February 20, 2010 12:23:18 PM(UTC)
thanks ,
jim
Jim,
Have you measured the voltage between the legs?
What happens if you push the start button with the door closed?
jemetz49
#5 Posted : Saturday, February 20, 2010 5:43:22 PM(UTC)
jemetz49
Jim,
nothing happens with door closed, no buzzer, no nothing
Jim
Wll check for 220 figured 110 and 110 was 220 on block
#6 Posted : Saturday, February 20, 2010 6:18:49 PM(UTC)
Check the voltage between the two legs with the door open.
Kenmore Elite dryer won't run... (Dryer Repair)
by J C Jones 9/11/2021 9:09:42 AM(UTC)
Kenmore Dryer won't run (Dryer Repair)
by gman536 3/14/2021 3:37:08 PM(UTC)
Dryer won't run unless start button is held down - no heat (Dryer Repair)
by jstrefeler 9/24/2017 12:10:11 PM(UTC)
Dryer WOn't Run (Dryer Repair)
by wstvpawjr13 5/14/2017 12:23:41 PM(UTC)
Dryer won't run after releasing the on button (Dryer Repair)
by Heathers1988 11/9/2016 4:20:53 PM(UTC)
Amana Dryer won't run (Dryer Repair)
by Paige Tremblay 1/26/2014 6:06:08 AM(UTC)
dryer won't run (Dryer Repair)
by dymetz62 1/8/2014 5:00:20 PM(UTC)
by pmclaughlin@apins.com 4/9/2013 11:18:38 AM(UTC)
by Ronald Walls 3/19/2013 1:09:09 PM(UTC)
by Ronald Walls 3/19/2013 1:06:28 PM(UTC)
by loumemoli 7/2/2012 1:33:54 PM(UTC)
dryer won't run but heats up fast (Dryer Repair)
by w. carroll 3/28/2012 8:22:26 AM(UTC)
Dryer Won't Run (Dryer Repair)
by paul888 1/16/2012 1:37:57 PM(UTC)
Dryer won't run after start. (Dryer Repair)
by clparks 4/28/2011 9:49:25 AM(UTC)
by tterry 3/29/2011 10:49:47 AM(UTC)
