Rank:: Member
We recently bought a house and it came with a dryer. When we tried to use it, it shut off right when I released the on button. If I hold the button the dryer works and heat goes on after a while, but as soon as I release the button it stops. The dryer is a hotpoint gtdx100gm1ww
Joined: 6/13/2014(UTC) Posts: 781   Was thanked: 1 time(s) in 1 post(s)
The centrifugal switch on your motor is not working. It might not be switching on due to a little arm that triggers the switch. Or there may be a clog or lint preventing it from switching on. It may be the contacts inside the switch are burnt / corroded. It is possible to check for the reason. Watch Bill show you the idea in this video. https://www.youtube.com/watch?v=CaaqRXQERVc
