William H.
#1 Posted : Friday, February 19, 2010 12:51:24 PM(UTC)
William H.
The right front double burner is now heating fully on both the small and large burner. Can the burner be replaced or does the whole class top have to be replaced?
#2 Posted : Friday, February 19, 2010 3:49:27 PM(UTC)
You have to check both the switch and the heating element with an ohmmeter.
Any burner can be replaced separate.
Here is the Tech sheet.
Here is the Service manual.
Here are the breakdown diagrams and Replacement parts for JENN-AIR JES9800AAS Range - S/c S/i Ddraft Ele | AppliancePartsPros.com
mrbandit
#3 Posted : Friday, February 26, 2010 8:35:17 AM(UTC)
mrbandit
My downdraft cooktop starting doing this very thing yesterday. If I try to turn on the larger burner on the right side it will come on by itself. If I try to turn on the smaller burner on the right side they both come on. My wife was almost burned because of this.
Our cooktop is 2.5 years old.
#4 Posted : Friday, February 26, 2010 2:49:38 PM(UTC)
In order to provide most accurate advice we need the complete model number of the unit.
