opened dryer to replace drum rollers,reassembled,had small spark on termial block,ground wire was touching common wire,now all i get is the buzzer to work when i open the door. any insight, mabe blown fuse and where is it located.
Thanks Jim
Hi Jim,
Have you checked the circuit breakers?
yes I checked them because when it sparked it tripped the breaker for the dryer. i have power to the termial block 110 on each leg, the only power i have is the buzzer when i open the door and push the start button.
thanks , jim
Originally Posted by: jemetz49 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) yes I checked them because when it sparked it tripped the breaker for the dryer. i have power to the termial block 110 on each leg, the only power i have is the buzzer when i open the door and push the start button.
thanks , jim Jim, Have you measured the voltage between the legs? What happens if you push the start button with the door closed? Gene.
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Jim,
Gene. nothing happens with door closed, no buzzer, no nothing Jim Wll check for 220 figured 110 and 110 was 220 on block
Check the voltage between the two legs with the door open.
