Ronald Walls
#1 Posted : Tuesday, March 19, 2013 1:06:28 PM(UTC)
Ronald Walls
Replaced T-fuse, checked switches ,voltages, and your suggestion for next
#2 Posted : Wednesday, March 20, 2013 1:02:40 AM(UTC)
Includes a wiring diagram.
Parts for Admiral LNC7764A71 Dryer - AppliancePartsPros.com
You will have to check the motor start circuit.
I am assuming that the that there is no noise etc. when you try to start it. Also that you checked L1 to Neutral at the terminal strip in the unit and it was 120 volts.
If you set the timer to timed dry mid cycle the timer should advance.
If not then it is probably a power problem or the L/M contacts in the timer are not closing.
To check the motor circuit.
Unplug the unit.
Set the time to mid scale, auto heat mode. Attach one meter lead to Neutral on the power cord and leave it there.
Use the most sensitive meter scale and short the meter leads together before starting so you can see if the meter has a zero offset.
Now measure to both sides of the thermal fuse, both should be 0 ohms.
Next 1 on the motor, should be 0 ohms,
Next 2 on the motor should be a few ohms. The motor windings resistance.
Following readings should also be this.
Next S on the timer.
Next M on the timer., should drop to motor resistance when the start button is pushed.
Following readings are with the start button pushed.
L on the timer, should be motor resistance
L1 on the power cord, should be motor resistance.
Kenmore Elite dryer won't run... (Dryer Repair)
by J C Jones 9/11/2021 9:09:42 AM(UTC)
Kenmore Dryer won't run (Dryer Repair)
by gman536 3/14/2021 3:37:08 PM(UTC)
Dryer won't run unless start button is held down - no heat (Dryer Repair)
by jstrefeler 9/24/2017 12:10:11 PM(UTC)
Dryer WOn't Run (Dryer Repair)
Belarus wstvpawjr13 5/14/2017 12:23:41 PM(UTC)
Dryer won't run after releasing the on button (Dryer Repair)
by Heathers1988 11/9/2016 4:20:53 PM(UTC)
Amana Dryer won't run (Dryer Repair)
by Paige Tremblay 1/26/2014 6:06:08 AM(UTC)
dryer won't run (Dryer Repair)
by dymetz62 1/8/2014 5:00:20 PM(UTC)
by pmclaughlin@apins.com 4/9/2013 11:18:38 AM(UTC)
by Ronald Walls 3/19/2013 1:09:09 PM(UTC)
by loumemoli 7/2/2012 1:33:54 PM(UTC)
dryer won't run but heats up fast (Dryer Repair)
by w. carroll 3/28/2012 8:22:26 AM(UTC)
Dryer Won't Run (Dryer Repair)
by paul888 1/16/2012 1:37:57 PM(UTC)
Dryer won't run after start. (Dryer Repair)
by clparks 4/28/2011 9:49:25 AM(UTC)
by tterry 3/29/2011 10:49:47 AM(UTC)
by DarrelD 1/31/2011 1:09:02 PM(UTC)
