My washer filled went through the agitation cycle then the soak then nothing. You could hear the timer clicking during the soak then it just shut itself off. Is it the timer or something else that needs to be fixed. Please help!
Sorry posted the wrong model number. It is LXR7244JQ0
Check your lid switch, closing lid should close this switch with a clicking sound.
We've checked the lid switch, that doesn't seem to be the problem.
Gotta be a bad timer or open motor, need to check for voltage to the motor to isolate.
