jnheinz57
#1 Posted : Wednesday, May 21, 2008 8:52:14 PM(UTC)
jnheinz57
My washer filled went through the agitation cycle then the soak then nothing. You could hear the timer clicking during the soak then it just shut itself off. Is it the timer or something else that needs to be fixed. Please help!
jnheinz57
#2 Posted : Wednesday, May 21, 2008 9:11:09 PM(UTC)
jnheinz57
Sorry posted the wrong model number. It is LXR7244JQ0
#3 Posted : Thursday, May 22, 2008 2:27:07 AM(UTC)
Check your lid switch, closing lid should close this switch with a clicking sound.
jnheinz57
#4 Posted : Thursday, May 22, 2008 8:08:15 AM(UTC)
jnheinz57
We've checked the lid switch, that doesn't seem to be the problem.
#5 Posted : Friday, May 23, 2008 12:23:05 AM(UTC)
Gotta be a bad timer or open motor, need to check for voltage to the motor to isolate.
Washer won't drain or spin (Washer Repair)
by garywool93 3/19/2015 9:40:02 AM(UTC)
Whirlpool top load washer won't drain or spin. (Washer Repair)
by Owie55 3/6/2015 1:21:47 PM(UTC)
GE Front Load washer won't drain or spin (Washer Repair)
by rmgaris 2/8/2014 8:15:28 PM(UTC)
GE Washer won't drain or spin (Washer Repair)
by JenNC 1/30/2014 12:52:31 PM(UTC)
roper washer won't drain or spin (Washer Repair)
by Mr.Stormcrow 1/23/2014 10:03:40 PM(UTC)
Kenmore washer won't drain or spin (Washer Repair)
by jpaw24 11/11/2013 6:40:40 AM(UTC)
Kenmore 70 series washer won't drain or spin (Washer Repair)
by ImSR 10/12/2013 8:49:49 AM(UTC)
by Karen.Smith 3/18/2013 12:01:38 PM(UTC)
KitchenAid Washer won't drain or spin (Washer Repair)
by MSUMOM 3/14/2013 7:25:53 PM(UTC)
GE Front Loading Washer Won't Drain or Spin (Washer Repair)
by gblotter 2/8/2013 8:23:32 PM(UTC)
by smyrnaref 8/5/2012 11:06:04 AM(UTC)
whirlpool washer won't drain or spin, lid switch OK (Washer Repair)
by trip2012 6/18/2012 7:38:38 AM(UTC)
by helpplease911 4/3/2012 12:16:26 PM(UTC)
washer won't drain or spin in gentle mode (Washer Repair)
by Frub 5/8/2011 7:17:11 AM(UTC)
by bethandgil 4/12/2011 5:05:27 PM(UTC)
