cledfarm@aol.com
#1 Posted : Thursday, December 17, 2009 4:10:18 PM(UTC)
cledfarm@aol.com
Dryer operation seems normal for a few minutes. Then blows the fuse on one side of the power line. One section of the switch encased on the motor terminal connection has burned contacts points. Is my diagnosis of a bad motor OK?
Is your motor part no. AP3094245 OK for this model serial no. MP3825583?
I will order the motor when you provide the answers these questions.
Thank you
#2 Posted : Thursday, December 17, 2009 4:54:13 PM(UTC)
I would agree with you since you have found a problem with it.
One thing I would check though is the heater. Some times when they get hot they can sag and touch the case. Depending where it touches it could blow the breaker. You would most likely see an arc mark on the inside of the heater case.
Try running the unit on air fluff if it still blows then I would go with the motor.
This I cannot answer as I do not work for AppliancePartsPros, best to give them a call.
Amana Dryer (ned4655ew1) vent glows when door is open (Dryer Repair)
by Guest 7/2/2024 9:31:47 AM(UTC)
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
Samsung DV328AGW Dryer heats for 10 seconds then shuts flame off (Dryer Repair)
by attim0de 6/13/2024 8:07:31 AM(UTC)
Bosch electric dryer model WTVC6330US/10FD9007 (Dryer Repair)
by Guest 6/11/2024 9:40:58 AM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
Ge dryer will not stay on (Dryer Repair)
by Guest 5/10/2024 3:25:16 PM(UTC)
