AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW
Joined: 6/13/2024(UTC) Posts: 0 ![Canada Canada](/Content/images/flags/CA.png)
Hi Folks! New user here about to throw out my new to me 2 year old GE Combination Washer & Dryer Worked perfect until one month after the warranty expired. At that time, it would intermittently add water during the dry cycle leaving your clothes soaking wet. It's getting worse now. This is a condenser dryer. It was always run on a quality surge suppressor because I thought, right away, something could happen to the electronics. Anyway, I changed out the cold water valve (4 valve manifold) and then bought the WiFi option thinking it might have a firmware upgrade available - it doesn't I then took the plenum off and cleaned debris from the fan blades and the condenser. The plenum itself is clear. The heating element is hot. Airflow is high. No codes are present. The problem remains. When the dry cycle is almost done, typically with 25 minutes remaining for cool off, it injects a ton of water into the tub soaking everything. Btw, this is a common problem that no repair people appear to be able to solve. Model# is GFQ14ESSN0WW On a side note, it has a pressure switch that looks like a vacuum hose goes to it. Any idea what that does? Edit: My guess is that's what it uses to determine if there is water pressure and to set the H20 code... Any ideas before I lose my nut? Edited by user Thursday, June 13, 2024 11:24:05 AM(UTC)
| Reason: Not specified
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: TN Was thanked: 12 time(s) in 12 post(s)
Soakingwet, thank you for your question. Based on the information provided, there is a control failure. However, this could potentially be a communication failure from the user interface control to the main control. In a case like this, the most likely cause of failure would be the main control WH18X28357.
Dryer Repair
