pansie
#1 Posted : Friday, August 15, 2014 3:21:29 PM(UTC)
pansie
My dryer worked fine in the morning....tried to use it by the evening...wouldn't start. Interior light comes on; I can hear the start switch trying to "communicate" to the timer control; the belt around the drum is fine; and the heating coil appears to be intact.
#2 Posted : Saturday, August 23, 2014 4:34:41 AM(UTC)
Parts for Frigidaire FSE447GHS0 Dryer - AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/p...df/Webster/131911100.pdf
Check the thermal limiter (Item 36 in Section 02).
It should be 0 ohms.
Be sure to unplug the unit when doing this.
If it is blown also check/clean your vent system as that is the most common cause of it blowing.
Would also be good idea to check the heating element.
Unplug the unit and both wires at the heating element.
Measure the across the element, should be around 12 ohms.
Then measure from each side of the element to the heater case.
Both should be infinite ohms.
If not the element is grounded and should be replaced.
LG Dryer won't turn on, but light on inside drum. (Dryer Repair)
by pshoebri 4/22/2018 8:12:26 AM(UTC)
Help!! GE Dryer won't turn on unless you spin it (Dryer Repair)
by Ruben C 12/6/2014 4:46:28 PM(UTC)
dryer won't turn on until it has cooled (Dryer Repair)
by Cam2ron2502 6/7/2013 1:43:31 PM(UTC)
Dryer won't turn on the motor or heating element (Dryer Repair)
by axnst1 3/13/2013 6:03:28 PM(UTC)
Dryer won't turn on. (Dryer Repair)
by generic 7/24/2012 5:16:50 PM(UTC)
dryer won't turn on, also light stays on with door closed (Dryer Repair)
by mazw 7/24/2012 4:17:25 PM(UTC)
Maytag dryer won't turn on. nothing lit except light when open door (Dryer Repair)
by eprunty 6/22/2012 12:00:17 PM(UTC)
Roper dryer won't turn on need some help (Dryer Repair)
by Robdob363 2/2/2012 9:30:47 AM(UTC)
dryer won't turn on..code F01 displayed (Dryer Repair)
by leamarie 12/15/2011 5:56:44 AM(UTC)
Admiral Dryer won't turn on. (Dryer Repair)
by TheoT 11/22/2011 1:31:36 PM(UTC)
Dryer Won't Turn On (Dryer Repair)
by maverickaf 8/30/2011 6:24:28 PM(UTC)
Dryer won't turn on (Dryer Repair)
by Lisa M 8/4/2011 6:34:07 AM(UTC)
by daveh59 7/4/2011 4:43:58 PM(UTC)
dryer won't turn on (Dryer Repair)
by momvilla 6/2/2011 2:14:44 PM(UTC)
by idgie 1/24/2011 5:37:22 AM(UTC)
