The Admiral Dryer I bought 14 months ago completely died last night. I put a load of clothes in the ddryer and could swear it started, but this morning all the clothes were damp and the dryer won't turn on at all. I checked the plug and circuit breaker and duct (for a lint problem) and none of those things are the problem. Of course this dryer only came with a 12 month warranty:( . Can you tell me what you think it might be? Thank you!
it may be a problem with door switch, or thermal fuse at back of dryer, or timer, check to see that youare getting 220 volts and 110 volts across white +red +110 volts across white +black+ 220 across red+black at line cord
Im having the same problem, bought mine 13 months ago and it dont turn on, need help!
It turns out that our dryer was dine. The circuit breaker just for the dryer had gone bad. It was replaced and now the dryer works again.
It turns out that the dryer was fine. The circuit breaker, just for the dryer had gone bad and had to be replaced.....but it had nothing to do with the dryer!
