momvilla
#1 Posted : 14 years ago
momvilla
My timer is ticking away but when I push the start button...nothing. Where do I start to figure out if it is the motor or the board or "trash"? I replaced the timer about 6 months ago.
#2 Posted : 14 years ago
Replacement parts for WHIRLPOOL LEN2000JQ1 ELECTRIC DRYER | AppliancePartsPros.com
See the attachment for the wiring diagram
I think I would start with the thermal fuse (Item 7 in Section 3).
Unplug the unit and check the fuse with a meter should be 0 ohms.
Jiggery Pokery method is.
Unplug the unit.
Remove both wires from the fuse, short them together and tape them up so they will not short to the frame.
Plug the unit in and give it a try.
If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires.
Also clean/check your vent system and the blower as these are the most common causes of it blowing.
Next I would check the contacts on the push to start relay.
File Attachment(s):
LEN2000.pdf (346kb) downloaded 22 time(s).
momvilla
#3 Posted : 14 years ago
momvilla
Jiggery Pokery: Thank you, thank you, thank you! I hate calling a repairman if not necessary.
LG Dryer won't turn on, but light on inside drum. (Dryer Repair)
by pshoebri 7 years ago
Help!! GE Dryer won't turn on unless you spin it (Dryer Repair)
by Ruben C 10 years ago
dryer won't turn on (Dryer Repair)
by pansie 11 years ago
dryer won't turn on until it has cooled (Dryer Repair)
by Cam2ron2502 12 years ago
Dryer won't turn on the motor or heating element (Dryer Repair)
by axnst1 12 years ago
Dryer won't turn on. (Dryer Repair)
by generic 13 years ago
dryer won't turn on, also light stays on with door closed (Dryer Repair)
by mazw 13 years ago
Maytag dryer won't turn on. nothing lit except light when open door (Dryer Repair)
by eprunty 13 years ago
Roper dryer won't turn on need some help (Dryer Repair)
by Robdob363 13 years ago
dryer won't turn on..code F01 displayed (Dryer Repair)
by leamarie 13 years ago
Admiral Dryer won't turn on. (Dryer Repair)
by TheoT 13 years ago
Dryer Won't Turn On (Dryer Repair)
by maverickaf 14 years ago
Dryer won't turn on (Dryer Repair)
by Lisa M 14 years ago
by daveh59 14 years ago
by idgie 14 years ago
