AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer won't turn on the motor or heating element
My gas dryer has stopped working! The motor won't turn and the heating element produces no heat to ignite the gas! Other than the timer ticking, the dryer makes no sound! I don't hear the motor turning or the gas kicking on! So I ripped the dryer apart and here's what I found:- door switch works - start button works and when turned on I get 120V going across it! - I get no conductivity accross any connectors on the back of the Wrinkle Shield nobe (though I don't think this would matter) - I get conductivity across all of the thermocouples - timer ticks and I get 120 Volts between tan wire (back of timer) and a - bunch of different other wires (back of timer) (blue for example) - thermo fuse replaced (I was hoping it was this so I replaced it first), works - belt not brokenif I unplug the connector from the drive motor switch I get 120V across two wires (can't remember which two but I will check again) However, I get no voltage going from (I think) the drive motor switch to the motor! On the picture below I get no voltage across the two wires in the back of the motor switch (marked with red arrows):my gas dryer's drive motor switch - YouTubeSo questions: - Does this sound like my drive motor switch is bad? - Should the ignitor still start to heat up? - Could it still be my timer? - If there is something wrong with the high limit switch or the ignitor or any of the gas valves, shouldn't my motor still start spinning? Meaning is it possible that my motor isn't starting because one of the above itmes have gone bad? I would think it'd be the other way around, no? Meaning if the motor doesn't start = no heating initiated! So basically which relies on which to start first? Thanks! Any help would be great! axnst1 attached the following image(s):
Originally Posted by: axnst1  ...On the picture below I get no voltage across the two wires in the back of the motor switch (marked with red arrows)... Can you describe how did you do this test please? The heating part of the dryer should not work if the motor does not. Here are the breakdown diagrams and Parts for Whirlpool LGQ8000JQ5 Dryer - AppliancePartsPros.comGene.
Dryer Repair
