generic
#1 Posted : Tuesday, July 24, 2012 5:16:50 PM(UTC)
generic
My dryer won't turn on, I can hear the timer but it won't start. Could it be the relay?
#2 Posted : Wednesday, July 25, 2012 12:55:01 AM(UTC)
Here are your parts, includes a wiring diagram.
Replacement parts for Maytag PYE2300AYW DRYER- ELE | AppliancePartsPros.com
As you can see from the wiring diagram, this unit does not use a relay.
I am assuming that you not only can hear the timer but it also advances.
That tells you that you have power (Neutral to L1) for the motor.
The most likely cause is a blown thermal fuse (Item 5 in Section 5).
Could also be the door switch, the motor itself or timer contacts.
Check the thermal fuse with a meter, should be 0 ohms.
If blown also do the following.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal cut-off blows.
The hi-limit should have regulated the temperature so the fuse did not blow, that is why there is a new one with the thermal cut-off..
Note: That unless there is another problem in the unit the hi-limit should never have to open. It is just a safety device with the fuse being a backup safety device.
Just in case it is not a grounded element.
With all the below the high limit will also have to be replaced.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut)
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Maytag dryer won't turn on. nothing lit except light when open door (Dryer Repair)
by eprunty 6/22/2012 12:00:17 PM(UTC)
dryer won't turn on..code F01 displayed (Dryer Repair)
by leamarie 12/15/2011 5:56:44 AM(UTC)
Admiral Dryer won't turn on. (Dryer Repair)
by TheoT 11/22/2011 1:31:36 PM(UTC)
