dryer runs but glow plug dont work. i changed it out still nothing i put a new timer in still nothing. if the gas valve is bad wont the glow plug still light? ty for your help
You will need a meter to check things, post back when you get one.
ty rich i do have a meter i have 4 dryers down with same problem i know for fact most of the venting on the first floor was cloged that was taken care of. i also test them not connected to venting for test purpuis only. so I'm letting u know they problem where over heated?
Check for voltage at the main connector going to the gas valve/igniter area. If bad use the schematic to check which component is bad, probably the ovrload thermostat/thermal fuse.
ok ty rich i will do that monday let u know
ty rich it was the fuse in the back i tested it no power out so i jumped it for testing and works now ty very much sir
