seethinghate
#1 Posted : Friday, February 8, 2008 9:09:26 PM(UTC)
seethinghate
dryer runs but glow plug dont work. i changed it out still nothing i put a new timer in still nothing. if the gas valve is bad wont the glow plug still light? ty for your help
#2 Posted : Saturday, February 9, 2008 3:19:55 AM(UTC)
You will need a meter to check things, post back when you get one.
seethinghate
#3 Posted : Saturday, February 9, 2008 6:15:32 PM(UTC)
seethinghate
ty rich i do have a meter i have 4 dryers down with same problem i know for fact most of the venting on the first floor was cloged that was taken care of. i also test them not connected to venting for test purpuis only. so I'm letting u know they problem where over heated?
#4 Posted : Sunday, February 10, 2008 12:44:06 AM(UTC)
Check for voltage at the main connector going to the gas valve/igniter area. If bad use the schematic to check which component is bad, probably the ovrload thermostat/thermal fuse.
seethinghate
#5 Posted : Sunday, February 10, 2008 8:36:07 AM(UTC)
seethinghate
ok ty rich i will do that monday let u know
seethinghate
#6 Posted : Sunday, February 10, 2008 12:10:34 PM(UTC)
seethinghate
ty rich it was the fuse in the back i tested it no power out so i jumped it for testing and works now ty very much sir
Amana Dryer (ned4655ew1) vent glows when door is open (Dryer Repair)
by Guest 7/2/2024 9:31:47 AM(UTC)
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
Samsung DV328AGW Dryer heats for 10 seconds then shuts flame off (Dryer Repair)
by attim0de 6/13/2024 8:07:31 AM(UTC)
Bosch electric dryer model WTVC6330US/10FD9007 (Dryer Repair)
by Guest 6/11/2024 9:40:58 AM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
Ge dryer will not stay on (Dryer Repair)
by Guest 5/10/2024 3:25:16 PM(UTC)
