PSB
#1 Posted : Friday, July 26, 2013 2:16:12 PM(UTC)
PSB
We tried to self clean our GE Double oven and after reading these forms, that was something that we should not have done. We tried to clean the top oven first and we got the F9 error. After the oven cooled down and door opened, we now have a flashing "locked" light on the display for the oven.
With the door in the closed position(or door closure pin pushed in), the door lock motor will continue to cycle open/closed repeatedly. The door lock end switches do make contact and I check that the two end switches do have continuity when the motor cam makes contact with their arm/switch.
The two thermal contacts are "open" when checked with a meter.
What else should I check or need to replace?
Thank you,
Peter .
HumboldtRepairMan
#2 Posted : Friday, July 26, 2013 3:29:28 PM(UTC)
HumboldtRepairMan
f9 is generally a door lock motor theres a switch that goes out on those things or the mechanism gets jammed up check to make sure all things attached to that are working right if you can pop the top of the oven.....and yes avoid doing self clean alot of machines have problems after using it because the high tempatures..........just make sure you have 120v going to that switch in the door lock motor.......now if you don't have 120v going to that motor it would be a problem with your main board.....
PSB
#3 Posted : Friday, July 26, 2013 3:37:31 PM(UTC)
PSB
Thank you I will check the voltage now. I assumed since the motor is operating that 120 V power is being delivered to the motor.
HumboldtRepairMan
#4 Posted : Friday, July 26, 2013 3:41:14 PM(UTC)
HumboldtRepairMan
more then likely yeah the voltage is correct but you never know check it anyways.......around 80-90% of these calls i end up replacing the door lock motor but do a good examination on any related attached parts.
PSB
#5 Posted : Friday, July 26, 2013 6:20:25 PM(UTC)
PSB
The voltage was 115 v. a the motor leads. Screen flashed " locked". Seems like the door lock motor continues to receive the signal to operate the motor.
GE Double Oven Displays 'F97' Error Code (Oven Repair (including Ranges and Cooktops))
by Chainplate 12/2/2021 9:13:32 AM(UTC)
GE double oven JT5500SF6SS (Oven Repair (including Ranges and Cooktops))
by cjoneill 12/6/2020 2:00:27 PM(UTC)
GE double oven (both ovens) will not stay on (Oven Repair (including Ranges and Cooktops))
by KTBryant 9/18/2015 6:50:56 PM(UTC)
ge double oven door locked (Oven Repair (including Ranges and Cooktops))
by jswim788 1/31/2015 11:30:12 AM(UTC)
GE Double Oven Doesn't Reach Set Temperature (Oven Repair (including Ranges and Cooktops))
by cwtowne 11/25/2014 3:01:26 PM(UTC)
GE Double Oven (Oven Repair (including Ranges and Cooktops))
by SmoothOperator 7/29/2012 6:33:51 AM(UTC)
GE double oven(microwave+conventional) (Microwave Repair)
by ajitphoto 4/6/2011 2:22:21 PM(UTC)
Replacing oven strike in a top GE double oven (Oven Repair (including Ranges and Cooktops))
by bighank 1/9/2011 2:52:19 PM(UTC)
GE Double Oven Double F4 (Oven Repair (including Ranges and Cooktops))
by MRH 12/1/2010 6:28:43 AM(UTC)
ge double oven catches fire!! (Oven Repair (including Ranges and Cooktops))
by cfgoldbe 2/12/2010 10:07:49 AM(UTC)
ge double oven timer has stopped working (Oven Repair (including Ranges and Cooktops))
by emkaye 11/8/2009 7:19:35 AM(UTC)
GE double oven No bake functions (Oven Repair (including Ranges and Cooktops))
by BBB 4/17/2009 10:02:29 AM(UTC)
GE double oven not working (Oven Repair (including Ranges and Cooktops))
by bigreed67 2/19/2009 9:25:52 PM(UTC)
GE double oven NEED HELP! (Oven Repair (including Ranges and Cooktops))
by davetalife 11/20/2008 3:15:11 PM(UTC)
by jim heffington 11/29/2007 6:45:10 PM(UTC)
