jim heffington
#1 Posted : Thursday, November 29, 2007 6:45:10 PM(UTC)
jim heffington
Gentlemen, I hope you can help me. I have an electric GE double oven that is about 15 years old. Several weeks ago, I discovered the broiler was not heating. I examined the the element and saw a blister on it and ordered a new broiler element. My wife used the oven self cleaning mode before I received the element. The oven went through the clean cycle just fine. I switched on the just oven last night and the broiler element came on. When I switched it to broil, it did not heat. Has the oven switch failed internally? Have you ever seen a failure like this? Thanks for any help you can provide.
Regards,
Jim
#2 Posted : Thursday, November 29, 2007 7:05:53 PM(UTC)
The first thing I would check are the knobs for the oven thermostat and the selector switch.
The knob consists of two pieces: the outer part with the temperature settings (or mode marks on the selector switch knob) and the central piece which goes on the shaft.
If the outer piece got dislodged, then it's very easy to put it back in the wrong position (180 degrees around).
If it happened then the dial reading does not match the real setting.
If this is the issue, assemble the knob in the right way and, using couple drops of a Crazy Glue, attach both pieces together.
GE Double Oven Displays 'F97' Error Code (Oven Repair (including Ranges and Cooktops))
by Chainplate 12/2/2021 9:13:32 AM(UTC)
GE double oven JT5500SF6SS (Oven Repair (including Ranges and Cooktops))
by cjoneill 12/6/2020 2:00:27 PM(UTC)
GE double oven (both ovens) will not stay on (Oven Repair (including Ranges and Cooktops))
by KTBryant 9/18/2015 6:50:56 PM(UTC)
ge double oven door locked (Oven Repair (including Ranges and Cooktops))
by jswim788 1/31/2015 11:30:12 AM(UTC)
GE Double Oven Doesn't Reach Set Temperature (Oven Repair (including Ranges and Cooktops))
by cwtowne 11/25/2014 3:01:26 PM(UTC)
GE double oven (Oven Repair (including Ranges and Cooktops))
by PSB 7/26/2013 2:16:12 PM(UTC)
GE Double Oven (Oven Repair (including Ranges and Cooktops))
by SmoothOperator 7/29/2012 6:33:51 AM(UTC)
GE double oven(microwave+conventional) (Microwave Repair)
by ajitphoto 4/6/2011 2:22:21 PM(UTC)
Replacing oven strike in a top GE double oven (Oven Repair (including Ranges and Cooktops))
by bighank 1/9/2011 2:52:19 PM(UTC)
GE Double Oven Double F4 (Oven Repair (including Ranges and Cooktops))
by MRH 12/1/2010 6:28:43 AM(UTC)
ge double oven catches fire!! (Oven Repair (including Ranges and Cooktops))
by cfgoldbe 2/12/2010 10:07:49 AM(UTC)
ge double oven timer has stopped working (Oven Repair (including Ranges and Cooktops))
by emkaye 11/8/2009 7:19:35 AM(UTC)
GE double oven No bake functions (Oven Repair (including Ranges and Cooktops))
by BBB 4/17/2009 10:02:29 AM(UTC)
GE double oven not working (Oven Repair (including Ranges and Cooktops))
by bigreed67 2/19/2009 9:25:52 PM(UTC)
GE double oven NEED HELP! (Oven Repair (including Ranges and Cooktops))
by davetalife 11/20/2008 3:15:11 PM(UTC)
