BBB
#1 Posted : Friday, April 17, 2009 10:02:29 AM(UTC)
BBB
My problem is the key pad bake buttons/functions (for top and bottom ovens) works intermittently. I've read various appliance repair blogs on the internet & the most likely cause points to the ribbon cable on the control panel assy. I've cleaned, wiggled, bent, etc and at times I can get the bake buttons to function but only temporarily. I cannot definitely tell if the problem is with the control panel/ribbon cable assembly or the connector on the erc board.
Although I'm pretty confident the control panel (P/N AP3207356) is the part I need, I'm concerned that the mating connector on the control erc board could be the problem.
Your thoughts suggestions before I purchase a new control panel.
All other functions work on the stove.
#2 Posted : Friday, April 17, 2009 1:37:11 PM(UTC)
The model number you posted does not come up. Verify and repost it.
Is it an American model?
BBB
#3 Posted : Saturday, April 18, 2009 4:41:45 AM(UTC)
BBB
Typo, a typist I'm not :) s/b Model JKP48CF1CC or JKP48C0F1CC. Made by GE... made by ????
#4 Posted : Saturday, April 18, 2009 3:29:23 PM(UTC)
This model number looks much better.:)
Most likely the problem is a bad control panel and the part number you posted is correct.
Here are the breakdown diagrams and Replacement parts for GE JKP48CF1CC | AppliancePartsPros.com
