SmoothOperator
#1 Posted : Sunday, July 29, 2012 6:33:51 AM(UTC)
SmoothOperator
Both Doors (top and Bottom) will not close: There is about a 14 gap: So Oven continues to report door open when I try to use it. I have to use spacers (folded cardboard) and jimmy the doors shut. Needless to say this is rather inconvenient and probably not safe.
At first I thought it was the hinges and started looking to that.. but this prove to be a complicated process of removing the doors, also I don't think the hinges are the problem: Since both doors have the same problem and we only the top oven.
Strangely enought the AutoClean process seems to work and the doors are automatically lock during this process. However they never unlock. I have to power off the appliance to reset the entire thing.
So I this confirms my suspicion that it's not the hinges.
I am thinking it is something to do the with the locking mechanism?
Maybe it needs some WD40 ?
Any Help suggestions ?
Anyone else had this problem?
SmoothOperator
#2 Posted : Sunday, July 29, 2012 6:46:47 AM(UTC)
SmoothOperator
Correction the gap is 1/4 in not 14 :)
GE Double Oven Displays 'F97' Error Code (Oven Repair (including Ranges and Cooktops))
by Chainplate 12/2/2021 9:13:32 AM(UTC)
GE double oven JT5500SF6SS (Oven Repair (including Ranges and Cooktops))
by cjoneill 12/6/2020 2:00:27 PM(UTC)
GE double oven (both ovens) will not stay on (Oven Repair (including Ranges and Cooktops))
by KTBryant 9/18/2015 6:50:56 PM(UTC)
ge double oven door locked (Oven Repair (including Ranges and Cooktops))
by jswim788 1/31/2015 11:30:12 AM(UTC)
GE Double Oven Doesn't Reach Set Temperature (Oven Repair (including Ranges and Cooktops))
by cwtowne 11/25/2014 3:01:26 PM(UTC)
GE double oven (Oven Repair (including Ranges and Cooktops))
by PSB 7/26/2013 2:16:12 PM(UTC)
GE double oven(microwave+conventional) (Microwave Repair)
by ajitphoto 4/6/2011 2:22:21 PM(UTC)
Replacing oven strike in a top GE double oven (Oven Repair (including Ranges and Cooktops))
by bighank 1/9/2011 2:52:19 PM(UTC)
GE Double Oven Double F4 (Oven Repair (including Ranges and Cooktops))
by MRH 12/1/2010 6:28:43 AM(UTC)
ge double oven catches fire!! (Oven Repair (including Ranges and Cooktops))
by cfgoldbe 2/12/2010 10:07:49 AM(UTC)
ge double oven timer has stopped working (Oven Repair (including Ranges and Cooktops))
by emkaye 11/8/2009 7:19:35 AM(UTC)
GE double oven No bake functions (Oven Repair (including Ranges and Cooktops))
by BBB 4/17/2009 10:02:29 AM(UTC)
GE double oven not working (Oven Repair (including Ranges and Cooktops))
by bigreed67 2/19/2009 9:25:52 PM(UTC)
GE double oven NEED HELP! (Oven Repair (including Ranges and Cooktops))
by davetalife 11/20/2008 3:15:11 PM(UTC)
by jim heffington 11/29/2007 6:45:10 PM(UTC)
