specialk8
#1 Posted : Tuesday, May 7, 2013 5:08:34 PM(UTC)
specialk8
there was a power outaged everthing came back on execpt dryer pf code cam up.change out the thermistor,ccu,thermal fuse,door switch,dryer stll does not run.when pressing start button get a clicking sound from the ccu board.what is my nent option to try
specialk8
#2 Posted : Tuesday, May 7, 2013 5:11:30 PM(UTC)
specialk8
Originally Posted by: specialk8 Go to Quoted Post
there was a power outaged everything came back on execpt dryer pf code cam up.change out the thermistor,ccu,thermal fuse,door switch,dryer stll does not run.when pressing start button get a clicking sound from the ccu board.what is my next option to try
to resolve this issue
#3 Posted : Wednesday, May 8, 2013 1:59:41 AM(UTC)
Parts for Whirlpool WED8300SW0 Dryer - AppliancePartsPros.com
Sounds like you have replaced just about everything in the motor circuit.
I would check the circuit with a meter.
With the unit unplugged and the door closed and one meter lead on neutral at the terminal strip. Put the other meter lead onto P9-1 on the control board.
You should read a couple ohms (the run and start windings in parallel).
File Attachment(s):
WED8300.pdf (405kb) downloaded 6 time(s).
Amana Dryer (ned4655ew1) vent glows when door is open (Dryer Repair)
by Guest 7/2/2024 9:31:47 AM(UTC)
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
Samsung DV328AGW Dryer heats for 10 seconds then shuts flame off (Dryer Repair)
by attim0de 6/13/2024 8:07:31 AM(UTC)
Bosch electric dryer model WTVC6330US/10FD9007 (Dryer Repair)
by Guest 6/11/2024 9:40:58 AM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
Ge dryer will not stay on (Dryer Repair)
by Guest 5/10/2024 3:25:16 PM(UTC)
