there was a power outaged everthing came back on execpt dryer pf code cam up.change out the thermistor,ccu,thermal fuse,door switch,dryer stll does not run.when pressing start button get a clicking sound from the ccu board.what is my nent option to try
Originally Posted by: specialk8 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) there was a power outaged everything came back on execpt dryer pf code cam up.change out the thermistor,ccu,thermal fuse,door switch,dryer stll does not run.when pressing start button get a clicking sound from the ccu board.what is my next option to try to resolve this issue
Here are your parts Parts for Whirlpool WED8300SW0 Dryer - AppliancePartsPros.comSee the attachment for the tech sheet. Sounds like you have replaced just about everything in the motor circuit. I would check the circuit with a meter. With the unit unplugged and the door closed and one meter lead on neutral at the terminal strip. Put the other meter lead onto P9-1 on the control board. You should read a couple ohms (the run and start windings in parallel). |
THIS FORUM IS DEAD!!!!!!! |
