Replacement parts for WHIRLPOOL REX4635EW2 | AppliancePartsPros.comHere is a tech sheet. Note this is for a EW0 not an EW@ but yours should be very close to this.
http://www.servicematters.com/d...0Sheet%20-%203401728.pdfFirst turn the breaker off/on slowly a couple times. Sometimes you can loose Neutral without actually tripping the breaker and the motor requires 120 volts. Note that if the timer does not advance in timed dry mode there is an electrical 120 volt problem as it gets power directly from Neutral through the door switch to L1.
Better yet check it with a meter.
Next I would check the thermal fuse (Item 23 in Section 3), easiest to check with a meter. You could check it by unplugging the unit, remove the wires from the fuse, short them together, tape them up so they cannot short to the frame, plug the unit in and give it a try.
If the fuse is blown replace it ASAP as this is a critical safety device.
Also if the fuse is blown give the interior a good cleaning including the blower wheel/case, clean and check your vent system.
