rosestratton
#1 Posted : Friday, September 11, 2009 1:33:41 PM(UTC)
rosestratton
hi my dryer stop spining i took it apart belt is fine what next
#2 Posted : Saturday, September 12, 2009 3:37:59 AM(UTC)
Replacement parts for WHIRLPOOL REX4635EW2 | AppliancePartsPros.com
Here is a tech sheet. Note this is for a EW0 not an EW@ but yours should be very close to this.
http://www.servicematters.com/d...0Sheet%20-%203401728.pdf
First turn the breaker off/on slowly a couple times. Sometimes you can loose Neutral without actually tripping the breaker and the motor requires 120 volts. Note that if the timer does not advance in timed dry mode there is an electrical 120 volt problem as it gets power directly from Neutral through the door switch to L1.
Better yet check it with a meter.
Next I would check the thermal fuse (Item 23 in Section 3), easiest to check with a meter. You could check it by unplugging the unit, remove the wires from the fuse, short them together, tape them up so they cannot short to the frame, plug the unit in and give it a try.
If the fuse is blown replace it ASAP as this is a critical safety device.
Also if the fuse is blown give the interior a good cleaning including the blower wheel/case, clean and check your vent system.
Amana Dryer (ned4655ew1) vent glows when door is open (Dryer Repair)
by Guest 7/2/2024 9:31:47 AM(UTC)
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
Samsung DV328AGW Dryer heats for 10 seconds then shuts flame off (Dryer Repair)
by attim0de 6/13/2024 8:07:31 AM(UTC)
Bosch electric dryer model WTVC6330US/10FD9007 (Dryer Repair)
by Guest 6/11/2024 9:40:58 AM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
Ge dryer will not stay on (Dryer Repair)
by Guest 5/10/2024 3:25:16 PM(UTC)
