Jim
spctre@charter.net
#1 Posted : Friday, August 21, 2009 3:27:01 AM(UTC)
spctre@charter.net
Replaced agaitator one year ago as the original would not remain in place during cycle. The replacement was redesigned and almost immediately began leaving lint and pet hair on the final washed product. Is there not some type of filter cartridge that goes in the upper cone under the cap ? Otherwise I see no way for a non element filter to work.
Jim Strength
#2 Posted : Friday, August 21, 2009 5:05:05 AM(UTC)
You usually have a comb accumilator under the spin basket. It fills up with lint, then flushes off during spin.
Yours might be just clogged up with stuff. You will need to buy the special spanner wrench to pull out the spin basket.
spctre@charter.net
#3 Posted : Saturday, August 22, 2009 6:10:58 PM(UTC)
spctre@charter.net
Thanks richappy. I assume the spanning wrench can be purchased from AppliancePartsPros.com. At any rate, I'll check with them.
#4 Posted : Sunday, August 23, 2009 1:05:05 AM(UTC)
If you pull the agitator off, then shine a light in the basket, you should see the comb filter throught the holes in the bottom of basket. If none, you washer has none.
Jenn-Air JIM158XBRS2 freestanding ice maker HELP! (Refrigerator & Freezer Repair)
by DaveRicciuti 6/11/2019 12:18:15 PM(UTC)
jim123 (Washer Repair)
by jim 123 3/26/2015 12:59:17 PM(UTC)
Jimmy T. (Dryer Repair)
by Jimmy T. 7/27/2013 5:41:06 PM(UTC)
Jimkeyes (Refrigerator & Freezer Repair)
by JimKeyes 10/3/2012 1:06:39 PM(UTC)
jim (Refrigerator & Freezer Repair)
by jim baird 7/12/2012 11:40:58 AM(UTC)
Jim (Washer Repair)
by Jimm1 4/17/2012 6:04:21 PM(UTC)
Jim (Dryer Repair)
by jetoan123 3/16/2012 6:17:59 PM(UTC)
jim b56 (Oven Repair (including Ranges and Cooktops))
by jim b56 2/12/2012 8:51:37 AM(UTC)
jim Colucy (Washer Repair)
by Jim Colucy 9/4/2010 9:23:51 AM(UTC)
Jim E (Refrigerator & Freezer Repair)
by jim eckart 8/26/2010 11:28:36 AM(UTC)
by jim eckart 8/19/2010 4:59:14 PM(UTC)
by jim crane 8/16/2010 3:59:48 PM(UTC)
Jim Kennedy (Oven Repair (including Ranges and Cooktops))
by Jim Kennedy 1/6/2010 11:44:01 AM(UTC)
by Jim Kennedy 1/6/2010 11:41:53 AM(UTC)
jimmyb (Dryer Repair)
by jbradford 11/24/2009 6:07:56 PM(UTC)
