Everything seems to be working except there is no heat. Diagnostic code is A2 but the tech sheet does not tell me what part is needed for an A2 code.
Have you ran the full diagnostic tests as described in the tech sheets?
Make sure there is 240 VAC at the dryer power outlet.
Can you post the tech sheets?
I ran the diagnostic based on the tech sheet and got an A2 fault code. The tech sheet does not give an answer for the A2 code like it does all of the F fault codes.
Originally Posted by: Gene  Make sure there is 240 VAC at the dryer power outlet.
You have answered only one question. We can not see your dryer and you are the only our eyes and ears. Gene.
