debthrash
#1 Posted : Monday, June 29, 2009 9:20:58 AM(UTC)
debthrash
Everything seems to be working except there is no heat. Diagnostic code is A2 but the tech sheet does not tell me what part is needed for an A2 code.
#2 Posted : Monday, June 29, 2009 11:46:36 AM(UTC)
Have you ran the full diagnostic tests as described in the tech sheets?
Make sure there is 240 VAC at the dryer power outlet.
Can you post the tech sheets?
debthrash
#3 Posted : Tuesday, June 30, 2009 4:38:37 AM(UTC)
debthrash
I ran the diagnostic based on the tech sheet and got an A2 fault code. The tech sheet does not give an answer for the A2 code like it does all of the F fault codes.
#4 Posted : Tuesday, June 30, 2009 6:56:59 PM(UTC)
You have answered only one question. We can not see your dryer and you are the only our eyes and ears.
Amana Dryer (ned4655ew1) vent glows when door is open (Dryer Repair)
by Guest 7/2/2024 9:31:47 AM(UTC)
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
Samsung DV328AGW Dryer heats for 10 seconds then shuts flame off (Dryer Repair)
by attim0de 6/13/2024 8:07:31 AM(UTC)
Bosch electric dryer model WTVC6330US/10FD9007 (Dryer Repair)
by Guest 6/11/2024 9:40:58 AM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
Ge dryer will not stay on (Dryer Repair)
by Guest 5/10/2024 3:25:16 PM(UTC)
