dryer worked fine then suddenly won't come on checked breaker it is getting power is there a fuse in this dryer or a reset button?
Here are your parts, includes a wiring diagram Replacement parts for MAYTAG PYE1000AYW | AppliancePartsPros.comYes there a fuse. I believe it is on the heater assembly. If it is blown be sure yo clean/check your vent system and the blower wheel. Theses are the most common reason for it blowing. Also check the door switch. |
THIS FORUM IS DEAD!!!!!!! |
