sandyp624
#1 Posted : Thursday, March 26, 2009 4:49:46 AM(UTC)
sandyp624
dryer worked fine then suddenly won't come on checked breaker it is getting power is there a fuse in this dryer or a reset button?
#2 Posted : Thursday, March 26, 2009 5:31:59 AM(UTC)
Here are your parts, includes a wiring diagram
Replacement parts for MAYTAG PYE1000AYW | AppliancePartsPros.com
Yes there a fuse. I believe it is on the heater assembly.
If it is blown be sure yo clean/check your vent system and the blower wheel.
Theses are the most common reason for it blowing.
Also check the door switch.
Kenmore Elite dryer won't run... (Dryer Repair)
by J C Jones 9/11/2021 9:09:42 AM(UTC)
Kenmore Dryer won't run (Dryer Repair)
by gman536 3/14/2021 3:37:08 PM(UTC)
Dryer won't run unless start button is held down - no heat (Dryer Repair)
by jstrefeler 9/24/2017 12:10:11 PM(UTC)
Dryer WOn't Run (Dryer Repair)
by wstvpawjr13 5/14/2017 12:23:41 PM(UTC)
Dryer won't run after releasing the on button (Dryer Repair)
by Heathers1988 11/9/2016 4:20:53 PM(UTC)
Amana Dryer won't run (Dryer Repair)
by Paige Tremblay 1/26/2014 6:06:08 AM(UTC)
dryer won't run (Dryer Repair)
by dymetz62 1/8/2014 5:00:20 PM(UTC)
by pmclaughlin@apins.com 4/9/2013 11:18:38 AM(UTC)
by Ronald Walls 3/19/2013 1:09:09 PM(UTC)
by Ronald Walls 3/19/2013 1:06:28 PM(UTC)
by loumemoli 7/2/2012 1:33:54 PM(UTC)
dryer won't run but heats up fast (Dryer Repair)
by w. carroll 3/28/2012 8:22:26 AM(UTC)
Dryer Won't Run (Dryer Repair)
by paul888 1/16/2012 1:37:57 PM(UTC)
Dryer won't run after start. (Dryer Repair)
by clparks 4/28/2011 9:49:25 AM(UTC)
by tterry 3/29/2011 10:49:47 AM(UTC)
