Rol
#1 Posted : Thursday, July 26, 2007 1:43:46 PM(UTC)
Rol
This dryer just quit, checked for power to it,tried to start several times and the electronic control board got hot, is the board bad? Thank You for any help you can send my way
Adam / APP Team
#2 Posted : Thursday, July 26, 2007 2:34:10 PM(UTC)
Adam / APP Team
Rank: Administration
Groups: Administrators
Dear Rol,
If the dryer does not run it could be a number of things including: timer, start switch, door switch, thermal fuse, high limit thermostat, cycling thermostat or motor.
The start switch, door switch, thermal fuse, high limit thermostat and cycling thermostat can all be checked for continuity (they should have continuity if not that part could be the problem)
If you have the knowledge to read wiring diagrams you can find the 2 leads from the timer that supply the power out of the timer remove the wires and set the timer to the timed cycle and you should have continuity through those 2 wires if not suspect the timer.
If you hear a loud buzzing or if you can "help" the drum start to turn it could indicate a bad motor.
If the board gets hot very quickly when you try to start it may indicate the power is stopping there and is defective.
Amana Dryer (ned4655ew1) vent glows when door is open (Dryer Repair)
by Guest 7/2/2024 9:31:47 AM(UTC)
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
Samsung DV328AGW Dryer heats for 10 seconds then shuts flame off (Dryer Repair)
by attim0de 6/13/2024 8:07:31 AM(UTC)
Bosch electric dryer model WTVC6330US/10FD9007 (Dryer Repair)
by Guest 6/11/2024 9:40:58 AM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
Ge dryer will not stay on (Dryer Repair)
by Guest 5/10/2024 3:25:16 PM(UTC)
