had to replace heating element,both thermostats and thermial cut off. now dryer is running way to hot even at lowest setting.:eek:
The cycling thermostat is marked usually 145 degrees and located on the blower housing. Make sure you didn't replace it with a 248 degree thermostat.
thank you i will check that out tonight.
How To You Tell The Difference Between Thermostats Old And New Not Labeled
Put them in an oven and check with an ohmeter
