JEEP
#1 Posted : Tuesday, February 24, 2009 6:42:51 PM(UTC)
JEEP
had to replace heating element,both thermostats and thermial cut off. now dryer is running way to hot even at lowest setting.:eek:
#2 Posted : Wednesday, February 25, 2009 1:29:58 AM(UTC)
The cycling thermostat is marked usually 145 degrees and located on the blower housing. Make sure you didn't replace it with a 248 degree thermostat.
JEEP
#3 Posted : Wednesday, February 25, 2009 4:39:13 AM(UTC)
JEEP
thank you i will check that out tonight.
JEEP
#4 Posted : Thursday, February 26, 2009 4:37:22 AM(UTC)
JEEP
How To You Tell The Difference Between Thermostats Old And New Not Labeled
#5 Posted : Thursday, February 26, 2009 5:53:09 AM(UTC)
Put them in an oven and check with an ohmeter
Amana Dryer (ned4655ew1) vent glows when door is open (Dryer Repair)
by Guest 7/2/2024 9:31:47 AM(UTC)
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
Samsung DV328AGW Dryer heats for 10 seconds then shuts flame off (Dryer Repair)
by attim0de 6/13/2024 8:07:31 AM(UTC)
Bosch electric dryer model WTVC6330US/10FD9007 (Dryer Repair)
by Guest 6/11/2024 9:40:58 AM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
Ge dryer will not stay on (Dryer Repair)
by Guest 5/10/2024 3:25:16 PM(UTC)
