The dryer doesn´t drye the clhotes, it works but doesnt burn gas, the ignitor doesnt get energy, then it doesnt get red, and the circuit looks ok
Check that your getting 120 volts to the ignitor if you are replace it. If not it could be a number of issues including thermal fuse, Timer, Motor centrifugal switch, etc
Originally Posted by: Fausto  The dryer doesn´t drye the clhotes, it works but doesnt burn gas, the ignitor doesnt get energy, then it doesnt get red, and the circuit looks ok I´ve the diagram
Originally Posted by: cammyj1967  Check that your getting 120 volts to the ignitor if you are replace it. If not it could be a number of issues including thermal fuse, Timer, Motor centrifugal switch, etc I don´t have 120 volts, just in one side, when I put the multimeter I have neutral but dont positive
Originally Posted by: Fausto  I don´t have 120 volts, just in one side, when I put the multimeter I have neutral but dont positive Can I feed 120 volts to ignitor from a diferent source?
I would check your thermal cut out. feeding power from another source would tell you if your ignitor is good but however will not solve your issue. i would check the thermals first.
if you have an ohm meter a quick ohms check across the ignitor will tell you if its good. If open replace. if it shows continuity its probably ok.
