Fausto
#1 Posted : Saturday, February 12, 2011 1:48:48 PM(UTC)
Fausto
The dryer doesn´t drye the clhotes, it works but doesnt burn gas, the ignitor doesnt get energy, then it doesnt get red, and the circuit looks ok
cammyj1967
#2 Posted : Saturday, February 12, 2011 1:51:22 PM(UTC)
cammyj1967
Check that your getting 120 volts to the ignitor if you are replace it. If not it could be a number of issues including thermal fuse, Timer, Motor centrifugal switch, etc
Fausto
#3 Posted : Saturday, February 12, 2011 1:54:27 PM(UTC)
Fausto
I´ve the diagram
Fausto
#4 Posted : Saturday, February 12, 2011 1:57:04 PM(UTC)
Fausto
I don´t have 120 volts, just in one side, when I put the multimeter I have neutral but dont positive
Fausto
#5 Posted : Saturday, February 12, 2011 2:03:13 PM(UTC)
Fausto
Can I feed 120 volts to ignitor from a diferent source?
cammyj1967
#6 Posted : Saturday, February 12, 2011 2:06:40 PM(UTC)
cammyj1967
I would check your thermal cut out. feeding power from another source would tell you if your ignitor is good but however will not solve your issue. i would check the thermals first.
cammyj1967
#7 Posted : Saturday, February 12, 2011 2:07:55 PM(UTC)
cammyj1967
if you have an ohm meter a quick ohms check across the ignitor will tell you if its good. If open replace. if it shows continuity its probably ok.
Amana Dryer (ned4655ew1) vent glows when door is open (Dryer Repair)
by Guest 7/2/2024 9:31:47 AM(UTC)
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
Samsung DV328AGW Dryer heats for 10 seconds then shuts flame off (Dryer Repair)
by attim0de 6/13/2024 8:07:31 AM(UTC)
Bosch electric dryer model WTVC6330US/10FD9007 (Dryer Repair)
by Guest 6/11/2024 9:40:58 AM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
Ge dryer will not stay on (Dryer Repair)
by Guest 5/10/2024 3:25:16 PM(UTC)
