Replacement parts for KENMORE 41784072300 | AppliancePartsPros.comHere is the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Webster/1342003e_sheet_1.pdfFirst thing to check is that the unit si getting 240 volts.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR] Then I would double check the hi-limit thermostat.
Be sure to disconnect one side of it to be sure you do not read an alternate/parallel circuit path.
It should be 0 ohms.
Then I would check the thermistor.
