kbtrapp
#1 Posted : Sunday, January 30, 2011 12:38:20 PM(UTC)
kbtrapp
I install a new heating element in my dryer and it still does not heat. It only has 120 volts to the element and the thermostat show good. How does this system work.
#2 Posted : Monday, January 31, 2011 3:21:06 AM(UTC)
Replacement parts for KENMORE 41784072300 | AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Webster/1342003e_sheet_1.pdf
First thing to check is that the unit si getting 240 volts.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
Then I would double check the hi-limit thermostat.
Be sure to disconnect one side of it to be sure you do not read an alternate/parallel circuit path.
It should be 0 ohms.
Then I would check the thermistor.
kbtrapp
#3 Posted : Monday, January 31, 2011 6:27:59 PM(UTC)
kbtrapp
Thanks for the wiring diagram, the L1 and L2 both have 120 volts . I have determine that the heater relay is open, I do have have 125 volts coming out of the blk heater relay wire.
#4 Posted : Tuesday, February 1, 2011 1:22:50 AM(UTC)
But do you have 240 volts between L1 and L2.
The heater circuit (L1 to L2) is 240 volts so measuring with one meter lead on Neutral or earth ground (unit frame) does not really tell you much and can be confusing.
You cannot tell if you are measuring L1 or L2 voltage.
As an example if I assume that the heater relay is closed, the unit is running but I have no heat. Hi-limit and heating coil are good.
With one lead on Neutral, I will measure 120 volts on the L1 side at every component all the way to M1 on the centrifugal switch. I am measuring the L1 voltage.
If I then measure to M2 on the centrifugal switch, I will also see 120 as now I am measuring the L2 voltage.
Now if I take the meter lead off Neutral and place it on L1. I measure 0 volts all the way to M1. I also now see 240 at M2.
Now if I move my leads to M1 and M2, I see 240.
What the above is telling me is that the centrifugal switch is not closing because if it was there would be 0 volts across it.
I hope I explained the above in a way that makes sense.
kbtrapp
#5 Posted : Tuesday, February 1, 2011 7:34:23 AM(UTC)
kbtrapp
Thanks I do have 240 volts measure voltage across L1and L2. Also I unplug the wire terminals from the heating element and had 120 volts on the M1 wire going to the element and 0 volts on Blk wire coming ouit of the heater relay.
#6 Posted : Tuesday, February 1, 2011 1:07:04 PM(UTC)
I am assuming the above was with the unit running.
So the voltage at M1 would be L2 and it looks like the relay on the board is not closing.
If the control thermistor measures good then I think you need a new control board.
Amana Dryer (ned4655ew1) vent glows when door is open (Dryer Repair)
by Guest 7/2/2024 9:31:47 AM(UTC)
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
Samsung DV328AGW Dryer heats for 10 seconds then shuts flame off (Dryer Repair)
by attim0de 6/13/2024 8:07:31 AM(UTC)
Bosch electric dryer model WTVC6330US/10FD9007 (Dryer Repair)
by Guest 6/11/2024 9:40:58 AM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
Ge dryer will not stay on (Dryer Repair)
by Guest 5/10/2024 3:25:16 PM(UTC)
