James Hummell
#1 Posted : Tuesday, December 21, 2010 11:15:32 AM(UTC)
James Hummell
How do I go about puting on a balt on?
Joe / APP Team
#2 Posted : Tuesday, December 21, 2010 2:20:22 PM(UTC)
Joe / APP Team
James,
Do you have the new belt ?
Part number: AP4379804
The procedure basically is :
***Unplug the power cord or turn OFF the breakers ***
Remove or raise the top
( open the door, there may be screws holding the top down to the front panel, no screws indicate the top is held in place by spring clips, one on each end of the top, you'll need to press in on the clips with a putty knife or something similar)
The front panel
Loosen(don't remove) the 2 screws holding the front panel to the cabinet frame on the bottom kick plate area.
Remove the 2 screws on the inside of the cabinet holding the upper area of the front panel to the cabinet flange, also disconnect the door switch or door switch harness, lean the front panel forward and lift the panel off the lower screws, the drum will disengage from the felt seal and glides attached to the front panel interior.
You will be able to install the belt between the drum and base from there.
Reverse to the procedure, after the belt is installed and test the dryer.
Good Luck,
Amana Dryer (ned4655ew1) vent glows when door is open (Dryer Repair)
by Guest 7/2/2024 9:31:47 AM(UTC)
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
Samsung DV328AGW Dryer heats for 10 seconds then shuts flame off (Dryer Repair)
by attim0de 6/13/2024 8:07:31 AM(UTC)
Bosch electric dryer model WTVC6330US/10FD9007 (Dryer Repair)
by Guest 6/11/2024 9:40:58 AM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
Ge dryer will not stay on (Dryer Repair)
by Guest 5/10/2024 3:25:16 PM(UTC)
