bdaddy711@aol.com
#1 Posted : Wednesday, July 13, 2016 6:00:46 PM(UTC)
bdaddy711@aol.com
GE refrigerator model TFX22KPDA AA. Ice maker not working. Ice maker motor is running but the tray does not fill with water. I checked the water line to the ice maker and it is clear. The water dispenser in the door is working fine. I pulled the cover and checked the micro switch for the water on the ice maker and it is working. I checked the continuity on the water valve solenoids and had continuity. I replaced the valves thinking there could be trash. I am still not getting water to the ice maker. :confused:
AUricle
#2 Posted : Monday, July 18, 2016 8:11:30 AM(UTC)
AUricle
Rank:: Member
bd,
Could be a low water pressure issue, especially if you have a Reverse Osmosis water system feeding the fridge. (Which might indicate an R.O. system problem)
Also you say the ice maker "motor is running"...but can you force a harvest cycle to see if the gear is actually driving the ejector blades? That's a possible cause.
Also, the icemaker has a thermostat that will stop the icemaker from working if its bad.....or if the temps inside the freezer are not cold enough for the thermostat to give the icemaker the ok to make a new batch of ice.
Just a few ideas....
Ice Maker not filling with water. Water dispenser works. Kenmore Elite (Refrigerator & Freezer Repair)
by jeffrich12 1/21/2023 9:13:34 AM(UTC)
KitchenAid Standalone Ice Maker Not Filling With Water After a Few Cycles (Refrigerator & Freezer Repair)
by jessep28 8/4/2014 2:58:30 PM(UTC)
Whirlpool GSS26C5XXY00 ice maker not filling with water (Refrigerator & Freezer Repair)
by amain 11/5/2012 12:35:22 PM(UTC)
Ice Maker Not filling with water (Refrigerator & Freezer Repair)
by sooscreek 9/7/2012 12:24:44 PM(UTC)
Ice Maker not filling with water, dispenser works fine (Refrigerator & Freezer Repair)
by RobinM3 11/15/2011 8:57:12 AM(UTC)
GE Monogram Ice Maker not filling with water (Refrigerator & Freezer Repair)
by apfander 7/16/2011 10:23:07 AM(UTC)
Amana Ice Maker not filling with water (Refrigerator & Freezer Repair)
by dlstorch 5/6/2011 8:20:07 AM(UTC)
Ice Maker not Filling with water (Refrigerator & Freezer Repair)
by rmoorhou 10/1/2009 4:17:41 PM(UTC)
by AlphaBob 5/12/2009 10:02:45 AM(UTC)
by dp860 4/20/2009 6:15:04 PM(UTC)
by bhbare 3/1/2009 7:33:25 AM(UTC)
by xochi 10/17/2007 2:04:24 PM(UTC)
