I replaced a broken Module on the Ice maker but now that is working there is no water coming out at each cycle.Can the water pump or relay be cheked to see if they are working properly?
Originally Posted by: xochi  I replaced a broken Module on the Ice maker but now that is working there is no water coming out at each cycle.Can the water pump or relay be cheked to see if they are working properly? RCA Ref mod#MSX20G due to cleaning inside freezer (45 mins ) - water coming into small reservoir FROZE and water can't reach the ice maker.
