The ice maker is not filling with water. the water dispenser in the door works fine. the auger in the ice maker works fine
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
did you ever find the solution? i have wasted hours trying to troubleshoot with no success.
